Welp, new KJ Owner in the house…
RedHotGTO
Fort Collins, CO
Got me a ’02 Sport to add to my herd…
Which also includes these…
Chevy
Goat
and Jeep
I bought the KJ for a little over $5200 with 120K miles and lots of leaks – which the dealership (Go Chevy in Denver) is addressing tomorrow.
She was born back on 8/25/01 with the 3.7, the auto, the 45RFE, the command-trak, and the taller springs.
She rides nice for having so many miles.
Now for a question…
How bad does this front end look like it is sagging?
Or is this about the norm for stock?
Luke
Interloper
Bancroft, Canada
Sorry .. I didn't read anything after GTO :D
Wow what a sweet ride ... always wanted one.
Welcome.
Jo6pak
Left coast of WI
Nice KJ.
The front looks very low. Looks like mine in fact, and my suspension is toatally bagged. Measure from the center of the wheel to the bottom of the flare to get a good idea how bad it is. My understanding is that ~19" is stock height. Mine sits below 18:icon_cry:
RedHotGTO
Fort Collins, CO
Hey Yawl - thanks for the welcome.
I measured and they are...
Front = 18-1/2"
Rear = 19-1/2"
Since this is a '02 should those numbers be 3/4" more?
Should the front and rear measurements be the same? On some cars/trucks the front wheel well is taller/bigger.
BTW - The tires are P225/75-16. (Wrangler ST)
Luke
Interloper
Bancroft, Canada
Heh heh .. we can all spot those tires a mile away... and in the best case scenario that's how far they should be from your Jeep. :D I have nightmares that prompt me to run to the garage to be sure that I replaced those things! lol
Not sure what the stock measurements from center of wheel to bottom of fender flare should be for an 02. They are pre-lowered and 3/4" higher than later years. There is a rake on them stock though but your pic looks like the front springs are sagged some. Time for a lift/new OME springs and Bilsteins .....hehe.
Welcome to the forum.
RedHotGTO
Fort Collins, CO
I hear you. Unfortunately, these tires still have some tread left on them - I will most likely wait till next Fall to replace them.
Thanks.
This Jeep will mostly be driven by my daughter while she attends CSU here in town, starting in August.
I will most likely just use stock springs and shocks from RockAuto (with a spacer or two).
So far this Jeep has required a bunch of work and still requires a bunch more which will keep me busy for several more weekends...
Completed in 3/2011
By Dealer, Go Chevy
Performed Emissions Test
Replaced leaking Power Steering Pressure line
Performed Power Steering Flush
Replaced leaking Oil Pressure Sensor
Replaced leaking T-Case Seal
Performed T-Case Fluid Change Service
Performed Engine Oil & Filter Change
Replaced Hood Props
Replaced 3 Wiper Blades
By Owner
Performed SeaFoam Service
Replaced Spark Plugs – ZFR6F-11G - Gap at 0.040
Replaced Air Filter
Replaced PCV Valve – P/N 53034065AA
Added Redline SI-1 Complete Fuel System Cleaner to full tank of gas
Replaced Driver side cracked Mirror
Sanded 8 Rusted Rock Chips and applied Stone White Touchup Paint
Washed undercarriage and removed 70% of the many years of leaking oils and dirt
Obtained Two New Keys – Dealer only had one to provide
ToDo during 4/2011
Perform Safety Recall – “F23 – Lower Ball Joints”
Perform four wheel Alignment
Clean and Polish Headlights with Mothers Restore kit
Sand Down Touchup Paint to Match Surrounding Surface
Perform Front Diff Fluid Service – 75w90
Perform Rear Diff Fluid Service – 75w90 + The Right Stuff gasket maker
Perform ****** Fluid and Filter Service – ATF+4
Perform Coolant Flush + Replace T-Stat
Perform Clevis Lift – 3/8
Replace Leaking A/C Condenser
Perform A/C Service
Install Floor Mats x4
Fix Driver Side Seat Recline feature – Replace Seat Latch
Replace Stripped Negative Battery Cable Bolt
ToDo after 4/2011
Perfrom Front Brake Service – Replace Rotors and Pads
Perfrom Rear Brake Service – Replace Rotor and Shoes and use spring kit
Perform Brake Fluid Flush
Replace Tires with something Beefy
Paint Stock Steel Wheels – Color TBD
Replace Springs and Rear Shocks / Front Inserts
In the CARFAX Report you can see where the first owner (4 years) did perform regular maintenance and the second owner (5 years) did not (at least not at a service center). He let things go that I am now needing to fix. Good play on his part to save the cash and just trade it in.
Jo6pak
Left coast of WI
"Performed SeaFoam Service" That does sound like alot more work than "Dumped a bottle of seafoam in the tank":whip:
Does the LBJ recall affect the 02? If so, you'll need to check into that.
RedHotGTO
Fort Collins, CO
See, that's the difference - I used a hose to suck it out of the bottle. Using that hose made it a service.
And actually, I did not put it in the tank – it went in the intake via a vacuum hose. And boy did I get some looks from the neighbors on Saturday – both in my driveway and as I drove down the block. Smoked like a ****. She thru a CEL due to all the fouling going on.
I looked up the VIN and that recall is still outstanding. Got an appointment this Saturday to take care of it.
Carguy836
South Lyon, Michigan
Just joined... so Hello All !
Just joined this forum. Glad to see so many Liberty experts in one place. I just read instructions on how to change my transfer case fluid. Thank, guys. You just saved me $80 at the dealership.
RedHotGTO
Fort Collins, CO
Welcome Carguy. It sure does feel good to keep your hard earned.
RedHotGTO
Fort Collins, CO
Hey All – So over the past week, I worked on the following…
- Completed by local Jeep Dealership
- Dealership would not include this with the recall. I tried to get them to include this using the argument that any time you replace a suspension part you must also perform an alignment. They would not budge. errrrrr
- The outside of the headlight lens now looks a little nicer. Now it is clear to me that the fogginess is on the inside of the lens.
Can the lens be removed so I can try to clean/polish the inside? Or is it a sealed unit?
- Some of the rock chips I touched up have faded away. And some I did not build up the paint enough – but those spots look 90% better.
- Completed
- Completed – only took about an hour.
- Completed. 68$ from the local Jeep Parts Dept – with the JEEP logo
- Would cost about $200 in just parts to fix. errrrrrrrr This fix will need to wait.
