Upper Control Arm Bolt Hole
Discussion in 'KJ General Discussion' started by dude1116, Jan 19, 2017.
  1. dude1116
    dude1116 Full Access Member
    3,370
    May 31, 2011
    Pompton Plains, NJ
    Hey guys!
    Quick question - are the bolt holes that hold the rear UCA to the body of the Jeep supposed to move around? Or did I break something? I don't remember them moving when bolting in the new arm...but after taking out the new arm I noticed the "nutsert" type things move around in the mounting hole. I would imagine after tightening this down it'll stay nice and still...but just wondering if this is normal.
    Thanks!
  2. rjkj2005
    rjkj2005 Full Access Member
    380
    Feb 25, 2016
    US
    No when you torque them down everything should tight. Torque them down with full wieght of the vehicle on the suspension so you put the proper preload on the bushings.
  3. dude1116
    3,370
    May 31, 2011
    Pompton Plains, NJ
    I know that! Just wondering why the threads are moving around the hole when I put the bolt there while the UCA was out being repaired.
    I don't even jack the Jeep up to take the UCA out/put it in.
  4. rjkj2005
    380
    Feb 25, 2016
    US
    If you didn't jack it up. How did you get the ball joint separated from the spindle
  5. rjkj2005
    380
    Feb 25, 2016
    US
    Sorry my bad. Didn't see you were working on the rear
  6. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    It's a captive nut,when the bolt is not tight it will move a bit.
    Major pain to repair if you mess that nut up.
    Best pic I could find of one in a similar unibody setup.
    [​IMG]
  7. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,697
    72
    That's good to know...thanks!
  8. dude1116
    3,370
    May 31, 2011
    Pompton Plains, NJ
    Good to know. It looks like it'll tighten down just fine. Was just slightly alarmed when it was wiggling around freely when I didn't notice it before. I always thought those bolt holes were in the body itself.
  9. krisP
    krisP Full Access Member
    483
    Nov 8, 2015
    NY/PA
    mine does the same but when tightened down its all good
  10. cplchris
    cplchris Full Access Member
    804
    Feb 10, 2010
    Albany, NY
    find a friend with some grim reaper hands and fingers to help you re-install the bolt and hold the nut in place.
  11. dude1116
    3,370
    May 31, 2011
    Pompton Plains, NJ
    The nut doesn't need to be held as it doesn't spin. It just moves. It really won't be hard to reinstall...but I was just making sure I didn't break the nut free from the body.
