Tri-Link and Other areas to Grease
Whelan
Milford, CT
So I'm going to replace the tri-link this weekend and also the lower control arms on the rear. Since I'm doing a 4-wheel brake job as well I figured I would take the opportunity to grease a bit.
I need some advice on if the control arms in the rear and tri-link should be greased and whats the best approach. Also same for the front arms since the wheels will be off.
Thanks in advance.
Myke
USA
If it doesn't have a zerk fitting you can hit it with some silicone spray lube. I tend to use it on my front sway bar mount bushings.
krisP
NY/PA
^ what he said. grease the brake slide pins thats about it
