Dizzydevil
3 weeks ago had my transmission replaced because it stopped working it slipped out of gear and got hot. Got replaced, then the transfer case selector was bad changed that got the truck back was driving for roughly 3 days out of the shop and the check engine light came on for misfires p0300 and p0302 and the transmission code p0700. Changed the spark plugs and coil packs, all the codes went away including the p0700. Drove fine all day Saturday and Sunday. Took on Highway this morning got up to 70 MPH and then exactly 30 miles out the check engine light came on and transmission temperature light too. I felt it slip gears and I immediately pulled over an shut it down checking the fluid level it was fine but steaming hot. Then checked code and p0700 was back transmission will not shift in reverse and it slips in drive and then doesn't move. So now back at shop this transmission is under warranty but what would cause this to happen twice on 2 separate transmissions ?
