Hi all,
I attempted to replace the transfer case fluid but failed to undo the fill plug.
I'm hoping I can remove it with some PB but it looks like I might have to remove the skid plate to get more torque on the plug.
I found an old thread on the forum citing a lost post regarding replacing the plugs that will fit a 19mm socket instead of a 10mm allen wrench.
Here's the lost post
LOST JEEPS • View topic - NV 242 darn 10mm allen plugs!!!!
Here's the NAPA part it refers to
NAPA AUTO PARTS
Changing it to a nut instead will allow me to use an extension in the future to avoid removing the skid plate.
1. Has anyone replaced their transfer case plug? if so what did you use?
2. the posts on lost seem to indicate that the gasket w/ the plug is not suitable. someone mentioned copper washer but I guess I could use some teflon tape??
Any other thoughts/comments?
thanks.
NAPA AUTO PARTS
thanks.
