TrakMotive XTENDED Travel CV Axles
liron sasson
hi guys
what do you think about the new
TrakMotive XTENDED Travel AM8005XTT​
It's worth it?
Been talking about them for a while now
well some of us have been LOL
Worth it , well that is up to you
I have ran over 135,000 miles at 4.5 inches of lift on the 04 with NAPA remanned ones
60 bucks compared to 120 some
So its back in your court
With all of the sites Im on no one has tried them yet as far as I know
So be the one that tries them for the next 100,000 miles
liron sasson
The problem with napa is They do not ship outside the US trying to find best solution
65Corvair
Iowa
They seem nice enough to try. On some cheaper replacement CVs, it seems like to boots get cracked and torn pretty quickly.
These list a "tough" thermo plastic boot that should be good.
I would try these if/when my current CVs wear out or the boots tear.
liron sasson
Thanks man
vlad588
Vancouver
Just want to share my experience with trakmotive cv-axle. I’ve been running one for over a year now and i can say they are not worth the money. The boot is made of hard plastic like material that cracks. I installed napa remanufactured cv-axle on driver side and trakmotive on passenger at the same time, napa is holding up much better with no issues, where trakmotive boot is starting to crack. So i would listen to oldtimers here and stick with napa remanufactured cv-axles.
Wavelight
hi guys
It's worth it?
These TrakMotive CVs are sold by NAPA for $250.00 each. Rock Auto has them for $125.00. I went with the NAPA way thinking about how easy it will be to get the lifetime warranty. I have re-turned under warranty 3 sets of the NAPA extended travel CVs due to the outer boots failing. The boots can not handle the suspension lift and turning of the wheel at the same time. It puts a dipple in the outer part of the boot. Once this happens, it's only a matter of time before a hole opens up in the boot.
So, I ordered the Rock Auto TrakMotive extended CVs X2 for $250.00 and returned the NAPA CVs and was reimbursed $500.00. Once I received the ones from Rock Auto I cut the original outer boot off the brand new CVs and replaced them with the Flexx boot you can buy off Amazon for $24.00. I bought the one that comes with the installation cone. I installed the boot exactly like the you-tube on Amazon video showed me. The Pleage furniture polish worked great. The boot seems to be of good quality. Time will tell.
No more problems with CV boots.
vlad588
Vancouver
Interesting, can you post a link to the exact flex boots of amazon you used? Thanks.
vlad588
Vancouver
Did you use small shaft or large shaft boot?
I use Bailcast silicone boots on everything I work on, don't know if you can get them in the US?
