What should the lug nuts on the 16X7.0 lux alum silver wheels be torqued to? I purchased the Mopar wheel locks and the directions say to use the torque setting specified in the owner's manual. The only reference I can find in the owner's manual is "Correct wheel nut tightness is 130 Nm (95 ft. lbs)" (p. 304). Is 95 ft. lbs correct for the aluminum wheels as well as the base model steel wheels? I thought aluminum wheels required a higher torque specification.
Also, do I need to loosen all the nuts on each wheel to install the wheel locks in order to retighten them in the crisscross pattern, or can I just remove one nut per wheel and replace it with a lock torqued to the correct tightness?
Thanks in advance.
___________________
2006 Jeep Liberty Sport
Thanks in advance.
___________________
