Torque converter
Mudvein
Corn field
Hey all!
I've got a 03 limited 3.7 4 spd auto 4x4. I find that since the super cold snap that the converter won't lock up until 62 mph. I don't remember it ever doing this until it got below 0 degrees. It's been in the 40's the past couple days and it's still doing it. Anybody else have his problem? Should I look for a rebuilt trans soon? Any help or experience is appreciated - thanks in advance Jeep lovers
Mudvein
PS the trans pan was replaced and trans flushed in the last year at dealer, and is still full
dude1116
Pompton Plains, NJ
Mine locks up around 55-60. I think you're good. Depends on your foot, usually. The computer adjusts how soon it shifts and locks. If you're concerned, get your CVI numbers checked at a trans shop to see if anything is out of spec.
A cold computerized transmission also could decide for itself:
I'm not switching at my normal speed until my fluid is well warmed up! :icon_lol:
Counting My Blessings
Forgive my ignorance, but what is this and what do you look/listen for?
Basically you listen for the rps to drop as it shifts from 3 to 4th (Overdrive)
Oh. I always turn OD off as soon as I put it in drive. No wonder I never could tell. :icon_lol:
dude1116
Pompton Plains, NJ
Actually it's an RPM drop after 4th. You should notice your jeep at about 2,000-2,100 or so RPMs around 50-55, then at about 60-65 it should drop to about 1,800 or so, maybe a little less. I've noticed it acts almost as a VERY steep fifth gear.
Emoto
SE Mass
I recall reading somewhere years ago (wish I could recall where!) that around 62 was when it was supposed to lock up. I kid you not. Since reading that, I often will try to notice when it happens on my 2002. It is usually right around there. So, I think yours is behaving as designed.
renegade 04
Albany New York
The real issue is that Chrysler has only one overdrive when they should have two overdrives. This is why I want the 545RFE.
ftaa
canada
the torque converter HATES locing up when it is cold.
04Liberty
MD
This is exactly what happens, especially with the RFE (if you have it). Fluid has to be a certain temp, until then (at least with the RFE's) it locks out OD.
Mudvein
Corn field
Thank you all for the input, I feel much better. Also, mine runs 2000 rpm at 60mph and 2500 at 70 or so, does that sound about right?
ftaa
canada
also fluid that i on it way out will play tric with the torque converter the viscoity goes down and mae it eem lie it i lipping and can damage the olenoid... o maybe it i time for a fluid change.
dude1116
Pompton Plains, NJ
I feel like I'm at about 1,900 and 2,200, respectively. But again, I'm sure it can differ somehow.
