What's the biggest tire I can run on a stock 2004 liberty sport I need tires but finding better deals on bigger sizes Thanks
It all depends on your suspension, if stock, never changed etc I have had ones 4-5 years old come in and have stock size rubbing due to springs that are stacked ( springs are sagged so low the coils are riding on each other in some cases ) and worn out shocks FIRST THING you do, on level ground, go to left front, measure from middle of the wheel, HUB AREA, to bottom of the flare On yours it would of been 19 inches when brand new or with new " stock " suspension ( that's new stock height ) if below that stay stock size, if at 19 then 245-70-16 is about it Some will say they ran larger ( at 19 inches ) but they will possibly rub on the pinch weld behind the front tire or on the area of the bumper in front of the tires.
