Since Covid I took my KJ off the road and used our family car. With lack of use, the transmission cable on the shifter got really tight or when I'd put it back in park it wouldn't actually go in all the way so the car would not start - the car sensing it was still in Drive. So I managed to go under the car and get it freed up a bit by spraying some WD40 and it seemed 100 percent again.
However after a day or two it starts to get a little tight again to begin with.
So what do people think? Just using the vehicle shifter frequently so it frees up with use? Or can I lube the cable with something? Better than WD40?? I'm hesitant to use something that could attract dirt and make matters worse...
Someone also mentioned a worn bushing in the transmission can make things tight but hopefully that is not the case here. It works just fine after I WD 40 and feels free and good for a day or two.
Any advice from the experts here would be greatly appreciated. Thanks
