Thread lock as thread sealant?
Discussion in 'Off Topic' started by uss2defiant, Nov 16, 2018.
  1. uss2defiant
    uss2defiant Full Access Member
    3,297
    I have a Mazda 5.
    There's a blind engine cover plug on the head that still has a slow oil leak. I used permatex high temp thread sealant when I tried sealing it the last time.
    Can I use blue 243 loctite as a thread sealant?
    The packaging says it'll prevent leaks.
    I wonder if the vibration cause it to come undone and cause it to leak.
    The threads is standard and is not a pipe thread.
    It has a copper crush washer which I've replaced too. 10ftlb is what is specified in the FSM.
    Couldn't find a conclusive answer googling around.
    Thank you.
  2. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,455
    71
    Not saying that it's right but I've used it for that. Seems like the washer should be doing the actual sealing.
  3. uss2defiant
    3,297
    Yeah. I would think so too but a new one didn't work so I'll have to redo it but I am thinking of trying blue thread locker to see if it holds better.
  4. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,642
    51
    What about some plumbers tape on the threads? (The cheap white stuff!)
    Edit: teflon tape...name escaped me
  5. uss2defiant
    3,297
    i think those would melt with the high temperature and I think those would work best with tapered threads.
    The thread lock seems to be holding up so far....
    fingers crossed
