Dealer Part number recommended for a gasoline 3.7 engine KJ Liberty is 68174083AA
195 degree Thermostat
Recommended Dealer reversed flushed Service Interval is Every 5 years regardless of mileage.
Replacement of Thermostat should be recommended /completed at time of Service.
Dealership has the correct flush machine and will use the correct HOAT coolant mixed correctly.
I want to make sure all of the above statements are true/correct.
So feel free to add to or correct me as above or below. :help:
Ok so now onto the other discussion part of this hopefully valuable thread.
Does The Mopar replacement thermostat as above fail to the open position or fails to the closed position?
Is there a better or more recommended replacement like a Prestone or MotoRad thermostat that will guarantee failing to the open position?
Or should we always use the Mopar Thermostat and why?
Should a complete cooling inspection including a 16 psi 2 minute pressure test be conducted before a flush?
What as owners should we be doing to our KJ..in between a flush ..like keeping the rad clean, checking the reservoir levels, cap pressure test..electric fan operations..hose inspect/replace..etc
With summer almost upon us & for further information, I want to add Troy has made a great statement in another thread which is really good info to know:
"Your electric fan does not turn on till about 219 degrees,heck your t-stat does not fully open till 218 degrees"
Post#11 Link: http://www.jeepkj.com/forum/f196/engine-temperatures-45992/index2.html
I assume That Troy's statement as above is with the 195 degree thermostat and air conditioning / compressor off as well.
Hopefully this helps search engines point to our Forum and answer the missing web info on the OEM spec of 195 degree on top of everything else!
I wonder to point to KJ country if tags could be beneficial to our threads?
