The Jeep gods are unkind today
Discussion in 'KJ General Discussion' started by smittyfromPA, Dec 3, 2013.
  1. smittyfromPA
    smittyfromPA Full Access Member
    200
    Nov 7, 2013
    PA
    Finally scraped up the cash to re-gear to 4:10's and add a Detroit TrueTrac in the front D30a. Also replacing both CV axles. Found a great shop that is also fixing an improper set up on a Track Loc in the rear 8.25, and a failed transfer case sensor. So I wake up happy as a clam as it is due to be picked up today and I can start the break in period on the gears. At lunchtime I get a phone call that I also need a new passenger side intermediate shaft (which is OK, I thought i might need it) and there seems to be a power steering leak. I asked them to track it down for me and am awaiting their call back. I had the PS pressure hose replaced last year and the PS pump replaced 2 weeks ago by the stealership. I'm hoping it was something like a loose hose and not a bad steering rack. Fingers crossed as the wallet is already light from the re-gear.
  2. Dave
    Dave Administrator Administrator Moderator
    15,590
    fingers crossed for you.....
  3. dude1116
    dude1116 Full Access Member
    3,369
    May 31, 2011
    Pompton Plains, NJ
    In my opinion the stealer should fix the power steering for free. They already charged you and didn't fix it/made it worse.
  4. profdlp
    profdlp On The Ledge
    4,985
    272
    Good luck, Smitty! :)
  5. tjkj2002
    tjkj2002 Full Access Member
    10,612
    Dec 17, 2006
    He does not know what is leaking yet,if it's not the pump the dealer is not responsible and the OP never stated why the PS pump was replaced.
    In 16 years in the auto repair field I have generally found once you fix one leak in a system another shows shortly after when you have 50k or more miles.Get's real bad after say about 150,000 miles.The fluids will always find the next weakest spot.
  6. Porkchop
    Porkchop Full Access Member
    1,288
    Jan 24, 2010
    Troy Mi
    And all leaks end up draining the pocket book to some extent.
  7. Jo6pak
    Jo6pak Full Access Member
    2,938
    108
    Nov 10, 2010
    Left coast of WI
    The Jeep gods are neither kind nor cruel.........merely indifferent.
  8. Dave
    15,590
    Yeah, leaks just don't go away.
    I wonder how smittyfrompa is doing with the leak and if they found/fixed it yet?
  9. tommudd
    tommudd Moderator Staff Member Moderator
    17,858
    453
    This is true, but any time I get a leak on a Jeep I sit cross legged on the top of it and meditate removing all leaking thoughts from my mind.
    It seems to work......................:shrug:
  10. Dave
    15,590
    I do that ...... and also light a "special cigar" and make some "holy smoke" while I am on top of the jeep....LOL
  11. ridenby
    ridenby Gold Supporter
    4,288
    Apr 19, 2009
    Kentucky
    Would bet on "O" ring on pressure line.
  12. smittyfromPA
    200
    Nov 7, 2013
    PA
    Thanks for all the posts and concerns. Leak was from a hose (not the high pressure hose) so all good. I pick it up tonight so i'll ask the shop exactly what it was.
  13. decibelchild
    decibelchild Full Access Member
    42
    Oct 22, 2013
    canada
    J.E.E.P
    Just
    Empty
    Every
    Pocket
    i love mine though still :)
