IAT
The IAT box changes the input to the PCM to make the Vehicle run rich,If it 100+ deg. outside you can set the box to make the PCM think it's 75 deg.
I have a 68mm and 70mm TB for a 2001 4.7L,We found the restriction to be in the cats and exhaust on that engine and not the exhaust manifolds,As you know one can't bump up the timing on the 3.7 without a PCM mod,But F.A.S.T and Roe Racing along with B&G have ways to mod the PCM.
You can go to KRC Performance home page and look at my Dyno run (4.7L)with and with out Headers,(JBA Headers),We also made a custon intake manifold for the 4.7,They say the 3.7L is a cut down of the 4.7.
For 2005 Jeep made changes to the heads,Lash Caps.
