kdx kawboy
- Joined
- Aug 5, 2023
- Messages
- 14
- Reaction score
- 14
While the 3.7L is known for lifter failures, I never had the problem with the the other Libertys I've owned. Had good luck. Today I think I loft the lifter on #4. Started the car. As I pulled out of the driveway I heard a ticking. By the time I was 100 yards down the road and the check engine light started flashing. Turned around. got home, attached the code reader, for a P0304, which the forum says can be caused when a rocker arm falls off the valve when a lifter fails. As I was hearing a ticking sound that changed nature but kept ticking with the check engine light I suspect the lifter and not the coil/spark plug.
Tomorrow is carpal tunnel surgery but my son is coming over to Wednesday to remove the vale cover so we can check the rocker.
