Sunroof Switch
MTKross
Florida
My sunroof switch has finally died and I need a new one for my 2004 Libby.
When looking for a new switch I noticed that the switch that says it works for the 04 is $65 where you can pick a switch up for a 05-07 for only $15. What the heck! Lol
So is the 05-07 the same connector as on the 04? They look pretty much identical otherwise.
Thanks for the help!
The connector is different. I have a sunroof in my 05 and 02. Both stutter a bit and I've been blaming the switch so I've just looked into this. The 05 is really bad so I was thinking of swapping them and found you cannot.
ugh..... didn't think that switch would be an issue.
Have you tried cleaning up all the rails and lubing them?
Tried that on the 02 and it didn't help. I will try it on the 05 but there seems to be plenty of good grease on the rails. Nothing looks dirty but have a feeling I may have been the first person to try it ever. I only tried it once last week.Opens ok but closing took some effort. I really don't use it very often especially during the pollen season around here :gr_grin:
I tend to not use mine too much either.
I sometime hear the plastic scraping sound when raising the rear of roof so it just vents.
I use some GLCI grease I have on the rails but doesn't seem to help.
Mine sound fine (both of them) but they stutter now and then. No unusual noises. When it stutters or stops there is no motor noise or anything. One reason I don't think it is the track is that it does it sometimes when I try to close the roof from the vent position and it isn't really traveling on the tracks much. I still plan on checking it out for crud but it looks pristine in there and the grease is greasy.
