Strut/spring/shock size
JustinJackson
BC, Canada
If I have a 2.5" day star lift in my 04 Kj then would I need longer shocks and struts and spring and everything? Or will stock size work? If so then what size should I go up to
jeeplib05
Ohio
No need for any of that because Daystar is junk and it'll all sag even more in no time
I wouldn't put any more money (suspension wise) into it until you can get a suspension lift, not a spacer lift
jharrisliberty
Colorado
Don't buy the daystar lift. And if you already did return it. I ran it for too long. When I pulled it off it was crap. And the suspension was like driving a boat on the open ocean. The front end rocked so bad that my wife started to get car sick at the end. Just don't do it. You are better with the worn out stock suspension.
Daystar no don't do it, cost you money in the long run. But as when lifting the proper way the front shocks ( we don't have struts ) are same no matter what. Use OME or Bilstein work the best on the front of KJs .
NOW for the rear yes you will need longer shocks depending on what height you go to.
