Sticking Solenoid?
David13
Central Utah Rocky Mtns
I posted about this before. Seems like the starter solenoid sticks or is bad and doesn't disconnect the starter thus causing the car to not start. But I couldn't get it to do it again. To repeat it, and it quit doing it for a long time, maybe a year.
Now it did it again about ten times, then it dropped back and allowed the motor to start. And it is not doing it again.
This time it was on a steep uphill climb maybe from 5000 to 8000 feet on a dirt trail. In 2 wheel drive.
I don't want to replace an otherwise good starter only to have it do it again. So what else could it be.
I thought maybe fuel pressure. I was on a little uphill (parked) when it did this again. Could it be the fuel pump is getting weak?
What else could cause that?
dc
Is it actually turning over? If it's not turning then starter or neutral interlock would be where I'd start looking
David13
No, it turns over. It appears or seems that the solenoid does not release, or kick out to let it start. It just keeps cranking.
Thanks
dc
So it keeps cranking when you release the key?
David13
No. It stops then. When I cut the key back to nothing, it stops.
All the classic signs of a bad solenoid. But. What else could be involved?
dc
DadOSix
Cumberland, MD.
dc
Key to start - starter cranks
Key released to run - starter still runs, or , starter stops
Off - all stop.
I am confused on step 2 - when you release the key from start to run - if the starter is still engaged, most likely a bad ignition switch.
David13
Thanks Dad, you have given me much to think about ... or test.
Part of the problem is recreating the problem. I have been intermittently going to start it to see if it does this again. Like above, it had quit doing it for many months.
I randomly tried it today and twice it did it. Then, third time, it starts normally.
I completely agree. It could be the switch. But also the solenoid or Bendix as it used to be known as.
I suppose I could take out the starter and clean it, see if it looks dirty from off road use or anything and then try it.
I suppose I could wiggle the key in the switch to see if that affects it.
Thanks
dc
DadOSix
Cumberland, MD.
Thanks
dc
Bendix - i didnt say that bc no one knows what it is !!
A sticky bendix will either / not engage, do all you hear is a whirr. Or will not disenegage / centrifugal force throws it home once the engine rpm is faster that starter. If it does not disengage , your jeep sounds like a thrashing machine.
David13
Like a thrashing machine. That is, trying to start but not starting because the starter, which has not disengaged, is slowing it down and causing it to stall out.
Yeah, I think that is what it is not doing. It does make some noise. But it may simply be the switch. I'm wiggling the switch to see if I can replicate the issue. Nothing yet.
What can I try?
dc
Put your multi meter on the wire from the key switch to the starter and a ground point, when the fault occurs, see if you still have voltage going to the starter with the key released if so it's the switch, if not the starter is sticking in the engaged position.
David13
KJ owner, thank you, those are good ideas.
However, I would need to have all that ready for when and if it were to do it again. The thing is very intermittant, that is, only happens on rare occasions, which occur I have no idea when.
And I would have to have long test leads to allow me to see the meter when I'm turning the key.
I think what I may need to do is take out the forward drive shaft, and maybe replace the cv joint on that as that also misfunctions on rare occasions. And then see if the solenoid or Bendix looks dirty, or clogged or anything out of the ordinary. Then replace the starter, if called for. Which may or may not solve the issue.
Thanks
dc
If you go off the back of the ignition switch you can put it in the center console.
However, like you are planning, it's often the starter getting stuck, happens more on manuals where dust from the clutch gets into them.
If you are going to the trouble of taking it out get some dry spray lube, once you have stripped and cleaned it give it a coat, that should help.
Glad I've got the diesel, 3 bolts and it's out!
