oblivionnewtonjohn
I replaced my entire front and back suspension/bushing two weeks ago. New Bilstein shocks with Moog springs, 2 weeks later, my driver's side rear has 1" of sag with. I measured center cap to top inner fender, 19" on both fronts and 20" passenger rear (is that normal, I see nothing binding to cause it to be an inch higher). I also measured both rear springs, roughly 7" on the rear drivers (sag side) and 8" on the rear pass side. I noticed it looked off parked in the carport so I took measurements. Springs are seated correctly on the isolators, nothing appears bound up. My only guess is crap quality springs and to go with OME as I should have to begin with. Cooper AT 245/70R 16"s
