Shank39
Replaced the output sensor and sensor on differential. Still not working. What the voltage supposed to b on the output transmission sensor
Don't forget to use weather proof wire connectors..oh..and get some wore looming (that's what the technical name is right?) Any, 20$ and a beer says that your issue.First I assume its a 02-05 , so did you replace the wires from the rear diff up to the frame. Mopar has a wiring kit to replace that, dollar against a donut thats where the issue is .
OH and welcome to JEEPKJ
Lol thanks I was stumped on thisYa real tech term is Corrugated Tubing. Or split loom tubing is good! :gr_grin:
[ATTACH=full]59025[/ATTACH]
Hey I know this thread is old but I’m trying to diagnose my kj and I have checked the sensors and wiring to all sensors I even hooked up a Snapon scan tool and can see the the sensors are all reading my speed but the cluster doesn’t show anything what are the chances that my cluster is BO
What year/model is your Jeep?
You can exercise the cluster by holding IN the Odometer Reset plunger while turning the ignition ON.
All the cluster lamps will light up and the gauges will move back and forth a few times.
This is not a diagnostic but will at least prove if all the gauges are capable of moving.
Most of the cluster is run by a BUS...if we know the year/model we can climb into the relevant Wiring Diagrams.
