What have you noticed in terms of on road effects?Got a Spartan in the rear of my Jeep - really helps with off road ability.
it drives fine - makes some click and bang noises every now and then, but the key is to not be too heavy on the throttle when turning. This is my 3rd vehicle with one in it so I have gotten used to how they drive. They can be very sketchy in the snow though, so that is something to keep in mind.What have you noticed in terms of on road effects?
That's an acquired taste also. Can actually get around better in the snow with one than without one... like get to/from work in my 2wd truck when my 4x4 is laid up.They can be very sketchy in the snow though, so that is something to keep in mind.
I've never had a Spartan, but to say it performs better on ice and snow than a LSD doesn't make sense to me. I now have a e-locker in the rear but my Torsen style LSD was great in the snow - no sketchy cornering behavior and much better traction than the open diff it replaced. I'd think the unpredictability of a Spartan (locking up mid corner) on ice and snow could risk putting you in the ditch, or worse.That's an acquired taste also. Can actually get around better in the snow with one than without one... like get to/from work in my 2wd truck when my 4x4 is laid up.
A limited-slip can be worse in the snow/ice than a locker, IME.
I’m on day 3 with my Torq locker and well it’s going to take some getting used to. I believe it’s because I have a stick that makes it so hard. Every time you shift it locks in and corners are something I’m still learning. It definitely hooks up though can’t wait to take it in the mountains.I have a TORQ locker for my rear differential as well. It’s not installed yet but it’s on my list of Jeep to-do’s. Works by the same principle as your Spartan locker.
You have more control with a manual. You will get used to timing shifts. Also use neutral when turning sharply while coasting.I’m on day 3 with my Torq locker and well it’s going to take some getting used to. I believe it’s because I have a stick that makes it so hard. Every time you shift it locks in and corners are something I’m still learning. It definitely hooks up though can’t wait to take it in the mountains.
A trac-loc LSD is a very different animal than a Torsen LSD. A Torsen will always give you gentle "lock up" (they never actually lock) but the way a trac-lock (internal clutch plates) behaves depends on how it was designed and set up - they can be very gentle or very aggressive, depending on the application (I have no experience with them). I had a terrifying snowy drive once in a work Chevy Trailblazer that I think had an Eaton E80 LSD (clutch packs that go from completely unlocked to fully locked in an instant) that sent me spinning off the road multiple times. My Torsens have always behaved beautifully in similar conditions.That's what most say, but I have 20 years with Lockrights. They are locked when you are on the gas; cornering or not.
The difference is the locker unlocks when you get off the gas, but a LSD (trac-lok style) has pre-load keeping both tires turning in unison. In one case, the LSD put me spinning across a snowy highway into the oncoming lane. Glad there was no traffic that moment.
Last night on my way home from work I noticed that it unlocks when you push in the clutch between shifts and locks back up as soon as you accelerate.You have more control with a manual. You will get used to timing shifts. Also use neutral when turning sharply while coasting.
All my locked rides are manual. I tried locking an auto once, and didn't like it very much.
What I mean when I say Detroit drive different is the whole locking and unlocking thing.Last night on my way home from work I noticed that it unlocks when you push in the clutch between shifts and locks back up as soon as you accelerate.
It’s totally drivable I just have to get used to it. I’ve always had Detroit lockers in my 4x’s and they drive completely different.
It will be interesting to see how the TORQ locker is with my automatic transmission after I get it installed.I’m on day 3 with my Torq locker and well it’s going to take some getting used to. I believe it’s because I have a stick that makes it so hard. Every time you shift it locks in and corners are something I’m still learning. It definitely hooks up though can’t wait to take it in the mountains.
I think it will be fine.It will be interesting to see how the TORQ locker is with my automatic transmission after I get it installed.
This is the rear axle right?Last night on my way home from work I noticed that it unlocks when you push in the clutch between shifts and locks back up as soon as you accelerate.
Agreed. The KJ uses a trac-lok style from the factory. A Torsen style you have go buy aftermarket.A trac-loc LSD is a very different animal than a Torsen LSD.
Yes it’s the rearThis is the rear axle right?
Check your tire air pressure. Is one tire especially worn? One dragging brake?
I don't have what you describe with the Lockright. And also not with a Detroit I had previously.
