Sludge Death.....
Discussion in 'KJ General Discussion' started by dougmac, Apr 20, 2015.
  1. dougmac
    dougmac Full Access Member
    66
    Apr 20, 2015
    Lake Stevens, WA
    I bought this mint 2004 with a seized up engine this weekend. I suspect she didn't have regular oil changes. Here is the results....
    [​IMG]
    [​IMG]
    Spun rod bearing that welded itself to the crank.
    [​IMG]
    The suction screen plugged with sludge.
    [​IMG]
  2. twowings
    twowings Full Access Member
    802
    Nov 23, 2014
    Tulsa, OK
    Nice score...what are your plans?
  3. renegade 04
    renegade 04 Full Access Member
    1,432
    Jan 3, 2014
    Albany New York
    That means a blown head gasket! That is what occurs when engine oil and coolant met. This happened to my fathers Durango 4.7 and we are in the process of rebuilding the motor.
  4. tommudd
    tommudd Moderator Staff Member Moderator
    17,063
    142
    The way some people take care of vehicles they should have their license revoked
  5. dougmac
    66
    Apr 20, 2015
    Lake Stevens, WA
    I plan to rebuild the engine. I picked up a used engine with a good lowers end yesterday.
    No coolant in the crankcase... just hardened sludge.
  6. profdlp
    profdlp Grouchy Old Cuss
    4,819
    100
    Good luck with the rebuild! :favorites13:
  7. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    6,307
    120
    ^X2 on the rebuild.:party52:
    That look like a real nice KJ, what is the miles on it? a 4x4?
    Sport model or? Post some more pics please! I bet you got a good deal on it! :gr_grin:
  8. nocTurNalX
    nocTurNalX Full Access Member
    122
    Mar 19, 2015
    GA
    That got through some beating! Glad you are up for the rebuild.
  9. theroofable
    theroofable Full Access Member
    377
    Oct 19, 2010
    Looks like sport 4x4 judging by the trail rated badge and trim.
  10. TwoBobsKJ
    TwoBobsKJ Full Access Member
    2,637
    Jan 28, 2011
    Northern Ohio
    That engine's guts look a lot like the internals of my original engine. Previous owner just didn't take care of it - you can tell by the brown/orange tint everywhere.
    Have fun with the engine swap - it's very gratifying to get it running again :waytogo:
  11. twowings
    802
    Nov 23, 2014
    Tulsa, OK
    Hope you are able to document the process...all of us will be facing a rebuild one of these days...or a swap (don't tell my wife!)
  12. Leeann
    Leeann Full Access Member
    2,263
    28
    Mar 9, 2013
    Maryland
    Looks like the internals of my friend's 1989 Dodge Omni w/2.2L. Her dad bought it from an old lady - and purchased the extended warranty from her, too. Turns out she'd never had the oil changed, just filled up when she got full-service gas. The extended warranty paid for a new long block (no rebuilts or short blocks available at the time). So she got a brand new motor, 4 tires and a few other things fixed for a grand total of $300. I think it had 40,000 miles on it when they bought it.
    That thing was a little tank. I liked that car.
  13. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,445
    67
    Those things were indestructible! I had a friend with a mid 80's Plymouth TC3 and a 2.2L Mitsubishi engine. Never changed the oil (a couple years at least) so I told him I'd do it. I took off the drain plug and nothing came out. Stuck a stubby screwdriver in a bit and about a quart and a half of chunky "stuff" came out. Reminded me of the La Brea tar pits. Filled it back up with the appropriate volume and a new filter and he drove that thing for another 3-4 years. Not sure if he ever changed the oil again but he claimed he did. :shrug:
  14. Leeann
    2,263
    28
    Mar 9, 2013
    Maryland
    Y'know, changing the oil on that motor was pretty damned easy....why wouldn't you?
  15. Snail Farmer
    Snail Farmer Full Access Member
    939
    Mar 10, 2012
    Fairmont, MN
    Why would I want oil in my engine? Oil is dirty and I want my engine clean!
  16. dougmac
    66
    Apr 20, 2015
    Lake Stevens, WA
    I picked it up from a dealer. The price including tax, license and title fees was $1500. 175,000 miles. The body is perfect except two tiny door dings. Nice interior. It has almost new tires on it. And, it is a 4x4.
    The bad rod bearing had the crank seized. Because I couldn't turn the engine, I couldn't get the torque converter unbolted and had to pull it with the converter still attracted. Needless to say, it was a struggle getting it out.
    I picked up a core engine that should have a good crank and rods for $150.
    I will try to take pictures as I go along.
  17. twowings
    802
    Nov 23, 2014
    Tulsa, OK
    (popcorn)
  18. mx3_ryder
    mx3_ryder Full Access Member
    351
    Jan 27, 2014
    troy VT
    For any reason you may need... I have a good crank, block, rods and pistons, one cylinder head, couple sets of timing chains including one new set with guides etc. and more. Let me know if you need something or get snagged along the way.
  19. dougmac
    66
    Apr 20, 2015
    Lake Stevens, WA
    Thanks! I appreciate it!
    I am in the Seattle area.. getting it here might not be so easy. I don't have it apart yet, but based on my preliminary evaluation, it looks like I may have all of the hard parts.
    I am a diesel engine guy. This is a little different than I am used to. I will definitely be asking you if i run into any snags.
    [​IMG]
  20. dougmac
    66
    Apr 20, 2015
    Lake Stevens, WA
    Tear Down Done
    I worked on the beast Saturday and got the engine torn down. I did some cleaning. I have the block loaded in my truck to get hot tanked.
    I removed the crankshaft and rods from the donor block. They look good. the crank has been ground once. The main and rod journals are both 0.25 mm under sized. The cylinders still have cross-hatching all the way to the top, so I am planing to just run a flex hone through them and call it good.
    The heads look good. They will get a good cleaning, some new valve seals, then back on they go...
    Here are some pictures.......
    [​IMG]
    Block stripped to the bone
    [​IMG]
    Lots of parts on the bench!
    [​IMG]
    Nice cross-hatching all the way to the top of the cylinder
    [​IMG]
    Crankshaft from the donor engine looks good
    [​IMG]
    The heads look good
    Looking at the spark plugs..... its apparent that the previous owner used the same strategy with tune-up maintenance as he did with oil changes.:Frustrated:
