Diggerfreek
First I want to send out a huge thanks to Mike08Liberty for taking to time to make this list for us
I will get the 4 inch stuff updated as soon as I can get numbers.............
Shocks Guide for the KK Liberty
FRONT Stock
OEM – 68031298AC (Export ONLY)
OEM – 68033219AB
KYB – 331017
REAR Stock (14” in – 23” out)
OEM – 52125094AC
OEM – 52125603AB (Export ONLY)
Monroe – 37203
KYB – 344404
KYB – KG5039
Fox Racing Shox – Non-Coil 2.0 Remote Res. 980-02-031-A (14” in – 23” out)
Fox Racing Shox – Non-Coil 2.0 Emulsion 980-02-024-A (14” in – 23” out)
FRONT Small Lift (Less than 4”)
Bilstein – F4-BE5-D916-H0
Skyjacker –
FOX Racing Shox – Coil 2.0 Remote Res. 980-02-040-A (11” in – 16” out) *custom fabrication required
FOX Racing Shox – Coil 2.0 Emulsion 980-02-000-A (11” in – 16” out) *custom fabrication required
REAR Small Lift (Less than 4”)
BDS – 55968
Bilstein – F4-BE5-6458-H6
Skyjacker – H7071
FOX Racing Shox – Non-Coil 2.0 Remote Res. 980-02-032-A (16” in – 26” out)
FOX Racing Shox – Non-Coil 2.0 Emulsion 980-02-025-A (16” in – 26” out)
FRONT Big Lift (4” +)
Skyjacker –
FOX Racing Shox – Non-Coil 2.0 Remote Res. 980-02-006-A (13” in – 19” out) *custom fabrication required
FOX Racing Shox – Non-Coil 2.0 Emulsion 980-02-001-A (13” in – 19” out) *custom fabrication required
REAR Big Lift (4” +)
Bilstein – F4-BE5-6248-H5
Skyjacker – H7071
FOX Racing Shox – Non-Coil 2.0 Remote Res. 980-02-039-A (17” in – 28” out)
FOX Racing Shox – Non-Coil 2.0 Emulsion 980-02-038-A (17” in – 28” out)
Rancho RS9000XL – RS9028 (17” in – 28” out)
Note: most of these shocks were searched with a 2008 Jeep Liberty as the search criteria. If you own a 2009 Liberty please double check to make sure the part numbers match up. Some places still list the 2008 as being a “KJ” model. Please double check all part numbers before ordering
FRONT Stock
OEM – 68033219AB
KYB – 331017
OEM – 52125094AC
Monroe – 37203
KYB – 344404
KYB – KG5039
Skyjacker –
BDS – 55968
Skyjacker – H7071
Skyjacker –
Skyjacker – H7071
