!88liberty
I am new to this forum. I am looking for some help with an issue.
My 2005 Liberty Renegade is having transmission issues. When I start driving it run like normal. after about 15 minutes my transmission drops down to what I think is 2nd gear and will not shift up or down. If I stop and turn off the ignition and start it back up, it runs fine again.
I thought it was the speed sensors so I changed both input and output. This did not help. I still have a P0700 code when I check the codes.
I also noticed that a mile or less before the transmission looses it mind. The tire pressure warning light flashes 3 time then goes out. After pressure light goes out I got about a mile and issue occurs.
Has anybody had this happen and how did you fix it.
