RustyRenegade's Rejuvenation
Discussion in 'Members' Journals' started by RustyRenegade02, Aug 6, 2020.
  1. RustyRenegade02
    RustyRenegade02 New Member
    Jul 14, 2020
    My recently purchased 2002 Jeep Renegade needs rejuvenation. I knew I'd be under it soon and the time has come to take the clutch out. I have suspension parts ordered as well.
    My impressions so far... PB blaster is worse than transmission fluid. Now the fumes are going away, I plan on turning wrenches in the morning.
  2. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,303
    464
  3. tommudd
    tommudd Moderator Staff Member Moderator
    18,116
    524
    Sitting low, may as well upgrade the suspension to OME now
    stock springs and shocks were junk in first ten miles
  4. sota
    sota Full Access Member
    1,567
    175
    PB Blaster, while it might stink, is a god chemical to me.
    I did the turbo upgrade on my one car, and before I started I sprayed EVERY bolt I could find with PB Blaster, then let it sit overnight. Broke NOTHING. Came apart like it'd never been heat cycled. Yea I took 4 days to do the job, spray/sit/wrench/repeat until everything is off, but not having to get replacement fasteners like exhaust studs made it all worth it.
    If you have the time, I highly recommend it.
  5. RustyRenegade02
    Jul 14, 2020
    Thanks for the link and the advise. I am going to pull and replace with a little elbow grease to refresh the surface and nothing more.
    I purchased the Luk replacement kit. I dont plan on treating it hard afterwards, it is just time for a replacements and this kit seemed better than most without mopar price
  6. RustyRenegade02
    Jul 14, 2020
    I am not going to doing much other than pull a trailer through a woods to build an off-grid cabin. I am going budget and would love to go bigger. Monroe 171577 struts and Monroe 37203 OESpectrum shocks for a little over $230
    I went ahead and got a refresh of ball joints, bushings, or anything with rubber that has deteriorated. Hopefully putting all the suspension parts in once it gets cooler. Right now, my focus is the clutch
  7. RustyRenegade02
    Jul 14, 2020
    ABSOLUTELY AGREE! I reordered several bolts and parts that looked DONE. Sprayed PBB on it and the next day I kicked myself for re-ordering the bolts. The PBB is certainly a new product to me. It stinks so bad put it works so freaking good!
    I am not spraying it in the garage again though. The next time I spray, I'll be outside and likely still have fans blowing...
  8. tommudd
    18,116
    524
    May last a year, did one install for a guy, just wanted the same as you mentioned. 2 weeks later was redoing his suspension to OME, still have the rear springs and Monroe shocks, plus the front Monroe coilovers after 13 years, just laying in the shop yet on the shelf LOL Less than 100 miles on them
    and front shocks ,........... not struts
