Rivnut specs
mindbomb
California
Rivnut size/thread specs for skids mounting
What's the MOPAR rivnut size specs (6505294AA) thats required for tcase skid installation?
Reason I am asking is that all the MOPAR part dealers sell each for 3~4$ + ~20$ which puts me at around 30$ for 5 rivnuts (1 spare) while Amazon sells 20 pcs for 6$ or 100 for 14$ with prime shipping - I just need to know the right size/thread etc
PS
will this tool work fine for inserting them?
https://www.amazon.com/dp/B00061SFDM?ref_=ams_ad_dp_asin_1
Thanks
mindbomb
California
Where it bolts onto the cross member just drill and run a bolt through, lots stronger and easier
and how exactly would I reach inside the crossmember to fit a nut from the other side?
Nah I think I'd stick with the manufacturer instructions, I just need to know the thread/diameter that's all.
Tog
AU
If you google how to install nutserts/rivnuts there are some good videos on how to do it. There is also one that shows how to make a tool to install them, that tool is nothing like the amazon one you put the link up for that is a pop riveter
mindbomb
California
Yea I am aware of that, thanks! It can also be done with a bolt, nut with same diameter ,piece of sheet metal, washer and wrench.
Found these on the forum:
1. Page Title
2. Homemade Riv-nut Tool
Super userful.
now I just need to find the rivnut specs so I could order it from Amazon..
The factory skids came with the tool (X) & 2 NUTSERTS. nutzerts?
Note manufacturer for the OEM was AVK industrial.
58322[/ATTACH]"]
I hope this might help...
mindbomb
California
Reach inside? Drill clear through, bolt it on like I stated MUCH stronger than the way the factory installs them.
Did a lot that way, none ever came off
Seen the factory install ones come off though
Yeah, if you can get to the other side just use a nut and bolt. It is better like tom said.
If not, you need a nutzert. One thing with the nutzerts is that you need to be real extra careful not to not to over-torque them or they will strip and not work and you will have to drill it out and start over.
Nothing I have tells the size of the bolts/nutzerts, just the OEM part numbers as already given.
One thing to check is the OEM bolts/nutzerts are more expensive than the aftermarket ones. It might be that the OEM ones are graded bolts and the aftermarket ones are not. Big difference.
blackhawk
Venezuela
Last year I tried with that "How to" but it's quite hard !! I ended up to weld it.
mindbomb
California
I'm a bit unclear on this procedure. I look under the truck and the cross member seems to be a closed iron rectangle. How do I reach inside to place the nut?
Or do I need to drill all the way through and use a extra long bolt?
Guess I'm missing something here.
From what I understood inability to reach for placing nuts IS the reason for using nutzerts-
"A blind installed threaded fastener is defined as a fastener with internal or external threads that can be installed into a panel, tube or other structure from the front side without need to see or access the backside, or “blind” side to complete the installation." (From AVK website)
Drill clear through the cross member
on the frame rail you have to use those rivnuts but that way only buying a couple . plus like mentioned much stronger
