Replace TCM?
Cactus
I have an '03 3.7 4X4 with about 95k miles on it. Over the last year it has developed an issue at highway speeds (it drives fine around town and on flat freeways). On a long hill at higher speeds/rpms, if it kicks down to third or second it will go into limp mode and throw the P1776 code (Solenoid Switch Valve is stuck in the Low/Reverse (LR) position). You can turn it off and restart it to take it out of limp mode, and the CLE will go away by itself after several cycles. I have changed the valve body to an upgraded one, but that didn't fix the issue. Solenoid pack was changed as well, and the problem persists.
What are the odds that the TCM is the culprit? I am planning to sell the car and am trying to decide if I want to take a $250-$400 risk by changing the TCM.
Thanks!
Cactus
If it has the 42rle trans, it doesn't have a separate TCM. 42rle is controlled by the PCM and the 45rfe had its own TCM.
Wonder what the chances are of the currently valve body have an issue with that switch valve?
Found a good article on it:
Thank you for taking an interest in this!
The 42RLE does indeed have a TCM. It is shown in the manual with specs for both transmissions (P. 8E-20) and if needed I can take a photo of it.
In regard to the valve body, I have actually replaced it twice. The first time was with a "remanufactured" unit (including solenoid pack). When that didn't work, I found another vendor who rebuilds them with the Sonnax kits and guarantees them for life. After extensive correspondence with the vendor I bought that one but it didn't fix the problem either. (I used the solenoid pack from the "remanufactured" unit.)
Check to see if there is a TCM on the passenger side fender. Some people do say the early 42rle's had a TCM but then people say they're wrong. My 2004 42rle DOES NOT have a TCM. Do you have a pic of your transmission pan?
24turbo
Alberta Canada
I have a 2003 with a 42rle.
I can 100% confirm it HAS a separate TCM. I can also confirm it has a 42rle.
PN 56044192AE
Google also confirms said PN is a TCM for a 42rle (lol)
To the OP- did you try car-part.com? Looks like they run about $150. As for your original question- no idea. My Tundra had a transmission problem and everyone said the transmission was the problem. I replaced the ECM as it was a cheaper option as a Hail Mary and it solved the problem
