Removing trilink mount
Akley88
PA
So I'll use the excuse that i am overly tired. But I'm at a loss on how to get the trilink mount off the ball joint. I loosened the top bolt and nut but that's where I'm stuck. Any hints or tips?
Aceofspades
Buffalo
I’ve had luck removing the whole assembly and work with it off the jeep
Use the pickle fork with a large screwdriver wedged in the gap
Keep in mind I don’t run the sway bar so it’s easier to acces the bolts
Most of the time its just way easier to remove the tri-link and bracket together. Most times they are rusted together so get it all out where you can work on it and see what you are doing
Akley88
PA
thats what i ended up doing. that was a much faster process then trying to work under the jeep.
