Removing Drive Shaft
stn
Northern US
All,
It's been a while since I've posted. Honestly since replacing my 02 Sport with an 05, I must say I find myself in the garage fixing things a lot less.
However my new machine did pick up a vibration when decelerating the other week. Today when I crawled under to remove the driveshaft for U-Joint replacement, I fond the four rear bolts would back out about 1/4 then stop.
I'm assuming some type of thread locker is used at the factory. ---Any tips/tricks/advice on getting them out or is it not worth the hassle for me to do it at home?
You can see them from other side of the yoke. I'd just hit them with some PB plaster and give them a few taps on the heads with a sledge hammer. I've never had an issue getting mine out, and it's been out more times than I'd like to admit.
stn
Northern US
Thank you sir. I sprayed them with PB Blaster, let them sit a few hours and they backed out easily. It looks like blue lock tite was used to hold them in.
Normally I would not have given up so easily....I guess I'm out of practice.
Thanks again.
stn
