Removing cruise button trim
How do I remove the trim piece around the cruise buttons on the steering wheel? I want to take them off so I can sew on a new steering wheel cover.
Birdman330
Des Moines, Iowa
I don't think they are removable, I'm trying to remember when I installed cruise on my KJ that either 2 or 4 screws hold the set up in on the spoke of the wheel. Are you planning on putting them back on afterwards or leave off?
It's two screws one on each side, and they're one piece.
I just want to pop them off so I can tuck the cover under them and then put them back on. Might repaint them too.
Birdman330
Des Moines, Iowa
You'll have to remove the whole thing you might be able to take the trim off the buttons once you remove them, pretty simple pop off the horn/air bag, disconnect them from their connectors unscrew and remove them.
04Liberty
MD
Pull the airbag (make sure you do that correctly), unscrew and pop out the cruise button assemblies.
