Rear window doesn't roll down.
LucasD
My back window hasn't worked since I've had my jeep. It slowly lowers itself as i drive. I took the door panel off and this was just sticking out inside the window area. Do I need to attach it to something or is it broken off?
DadOSix
Cumberland, MD.
There is a nylon (plastic) clip that is riding in the track of the window regulator. It’ll still be there , but there is a threaded section of that same clip that has broken or disintegrated.
Jeep Liberty 2002 2006 Window Regulator Repair Kit Clip Rear Left - Right CS73 - sorry - i can;t make the picture load tonite.
Him73067
Georgia
It is a bit tricky to remove and replace, but definitely replace the regulator. I have had good luck with a NAPA replacement. YMMV.
BigMopar440
Pueblo, Co
Also, some manufacturers have a new design for these and may not use the style that was OEM. So it may not have the part that you are holding in the pic.
NevMcGyver
Uitenhage, Eastern Cape, South Africa
I'm in full agreement here. That threaded section shears off. I had one of my windows do that... but obtaining a replacement part was hellish expensive here in SA. So, I did what I love to do... I made a plan and repaired it.
The repair took some time but was worth the effort.
It entailed finding a useable gauge of strong wire, and then by means of drilling appropriate holes, and threading the wire accordingly, then also forming the wire so that it does not seize against the guides.
Now I have a fully functioning window.
Sorry, can't send pics, as I'd have to open the door again to do so.
