Rear end taking a dump
Snail Farmer
Fairmont, MN
I ran to the gas station a little bit ago, and as I was pulling out to come home, the rear end of my Jeep started hopping. Kind of like if the wheels were spinning on a mixed hard/slippery surface. But I didn't see any ice on the road at all. When it happened the first time I immediately took my foot off the gas and disengaged the clutch. As soon as I started to take off again, it happened a second time. After that it drove normally the rest of the way home. I've never had a rear end go out on me before so I really don't know what symptoms to look out for. I'd appreciate if anyone could share their experience.
4x4kayak2112
tx
Interesting......one of our ambulances at work does it, work says that we turn too sharp, I call bs. Let me know if you find out anything
Sent with the power of children's screams!!!
What diff do you have in it? Is it open or trashlocked?
How long since fluid change ?
Could be a number of things I'd drop the cover and check it out
Snail Farmer
Fairmont, MN
Chrysler 8.25... 3.73 gears.. open. Last fluid change about 10 months ago with dino oil.. everything looked ok then no metal chunks or anything. Drove to work tonight and it felt fine. I'm stumped but I'll probably pull the cover of when I get a nice day and try to figure out what's going on.
Sent from my HTC One using the power of Mary's purse
TheBlueKJ
South Jersey
Same thing happens to mine every now and again normally only when I turn but I have an open diff hmmm
Snail Farmer
Fairmont, MN
Next time itdoes it watch your rpms your clutch might be slipping
sent by telegraph from my k30
Thanks for the suggestion but I know it's not the clutch slipping. It hasn't happened again since that first time, but something else has happened for the last two days. I stop at the gas station every night before work, and the gas station has a big dip in the entrance. As I'm turning right into the parking lot the Jeep gets off camber, and I hear a loud bang coming from the rear. Not sure if it's related or not though.
CactusJacked
Chicago Suburbs
I'd open her up and take a good look inside before driving it any more. Your spider gears might be getting ready to let loose. Right now, you might be able to salvage the diff. If something lets loose though, it's likely to take the ring & pinion gears with it. You could also have a broken ring gear tooth, which then means a total rebuild or replacement.
brokendad
Edmond, Oklahoma
Chunks
Maybe be something floating around in the rear axle, or could it be the ball joint in the tri-link setup? You said it was a noticeable low spot that you had to pull through. Although it really does sound like the clutches in a trash-lok gone bad.
