rear cargo shelf
Discussion in 'Fabrication' started by timmyb457, Sep 10, 2010.
  1. timmyb457
    timmyb457 Full Access Member
    25
    Apr 26, 2010
    Valparaiso, IN
    Well i decided to finally make a shelf for the cargo are of my jeep. It was easier than expected and took about an hour to actually build.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Its very strong, i put 100lbs on it and it didn't flex at all. All in all not bad for $24. if you're looking to do something similar and want details just let me know and I'll put up dimensions and stuff
    I started with a piece of ply wood 3/4" Thick (you can use any size you want) Cut to these specs ------v
    [​IMG]
    You will also need a 1" dowel rod, 1" pipe clamps (4), and carpet of your choice to cover
    Cut dowel rod to 45.5"
    You will need to use the pieces you cut off to glue to the underside near the back seats to level out the shelf (as the drawing shows)
    Godric likes this.
  2. ThunderbirdJunkie
    ThunderbirdJunkie Bronze Supporter
    9,422
    Oct 31, 2005
    Newport, KY
    Looks great, Timmy!
  3. Clyde Frog
    Clyde Frog Full Access Member
    1,840
    Dec 13, 2009
    Central Mass
    I definitely would like the details! I've been considering building one for a while but haven't found a "build sheet" online that I trusted.
  4. ptsb5a
    ptsb5a Full Access Member
    2,446
    Mar 29, 2006
    Northern Alberta, Canada
    Great idea for keeping gear outta sight. Looks good.
  5. jeepchic79
    jeepchic79 Full Access Member
    555
    Jul 14, 2010
    Northern Kentucky
    Ditto ! I also priced a few and they where way too much than i wanted to pay .
  6. timmyb457
    25
    Apr 26, 2010
    Valparaiso, IN
    updated original post with the dimensions. if you have any other questions just ask
  7. ThunderbirdJunkie
    9,422
    Oct 31, 2005
    Newport, KY
    Thanks Tim!
  8. jeepchic79
    555
    Jul 14, 2010
    Northern Kentucky
    Yes thank you !! You are awesomeness !
  9. Clyde Frog
    1,840
    Dec 13, 2009
    Central Mass
    You are my hero!
  10. wolverine1020
    wolverine1020 Full Access Member
    64
    Jul 27, 2010
    07023 Sorta Central NJ
    Very nice! Thanks.
    Will be attempting soon.
  11. autoboy454
    autoboy454 Full Access Member
    189
    Apr 14, 2009
    MASS
    you should make a hole in your cargo deck/cover and port it for the sub! Nice work!
  12. timmyb457
    25
    Apr 26, 2010
    Valparaiso, IN
    if i did that it would partially defeat the purpose of being easily removable incase i need the cargo area and seats down for something big
  13. badkittystt
    badkittystt Full Access Member
    531
    Nov 16, 2010
    St. Thomas, USVI
    That's pretty neat looking, great for hiding stuff in the back too.
    How easy is it to take out? It would be cool if there was a way to support and hinge the middle in case you only wanted half a shelf...
  14. timmyb457
    25
    Apr 26, 2010
    Valparaiso, IN
    I can have it out in about a minute
  15. Kugellager
    Kugellager New Member
    Sep 6, 2009
    Colorado
    They come out really quickly. You can see the version I built over 5 years ago where I used a textured paint instead of cloth for a covering. It has held up for just over 5 years now w/o much wear and tear. I used the back cargo shelf all the time.
    Look about 1/2 way down page two of my mods to get all the details.
    http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=59&t=5363&start=20
    John
  16. j-rod
    j-rod Full Access Member
    292
    Apr 28, 2010
    Farmington, WV
    this might be the answer to my problem with the wifes KJ!
    1 question. what is the height from floor to bottom of the shelf when installed? if it will clear the double stroller I might not hate the KJ trunk so much. LOL
    you got any better pics of how the mounting hardware is installed and how it is mounted?
  17. Clyde Frog
    1,840
    Dec 13, 2009
    Central Mass
    As long as the stroller doesn't go above the two black metal pieces of the back of the back seats, you should be fine.
  18. j-rod
    292
    Apr 28, 2010
    Farmington, WV
    I am really liking the idea.
    are the dowl rods strong enough? please sho how you attached them and they secure in place.
    I see another guy above here used metal rods. Im just curious.
  19. jcbll95
    jcbll95 JPOTM WINNER
    203
    Feb 6, 2008
    weston wv
    hey J-rod i have built one of these and have had a lot of wieght on it.(dont recomend driving with stuff loose up there just in case) I dont know if the double stroller will fit under it but our Jeep liberty sport jogging stroller will not unless you remove the tray from it. We will have to get together so you can see it in person.
  20. Kugellager
    Sep 6, 2009
    Colorado
    I put our strollers on top and use bungie cords to strap them on. The under part of mine is full of tools and roadside emergency kit.
    One of our strollers is a BOB and fits up top with no problems. If there were no junk it would fit underneath as well.
    I used metal as it is stiff and won't sag over time. The metal I used is just 3/8" (I think) rod from Home Depot.
    Like I said, I have had mine for over 5 years and no issues at all.
    John
