Random Thoughts Thread
Discussion in 'Off Topic' started by Bennett, Aug 12, 2006.
  1. Jo6pak
    Jo6pak Full Access Member
    2,916
    76
    Nov 10, 2010
    Left coast of WI
    I missed out on a set of 5 2014 Rubicon wheels for $250. Called the guy yesterday, they sold on Tuesday.:favorites68:
    Been researching lifts for the WK2. Seems like RRO, Eibach, Dobinson, and OME are the only options.
    RRO is out.
    Can't find much info on Dobinson
    Eibach seems OK and gets decent reviews.
    OME is the only that offers choice of coils, which makes me think that's the way I will go. OME Medium...once I squirrel away enough pennies.
  2. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,708
    81
    Last I looked, there's a shit ton of JK wheels/tires on CL in the Madison area.
  3. Jo6pak
    2,916
    76
    Nov 10, 2010
    Left coast of WI
    Yeah, I'm seeing lots also. There seems to be enough out there, so I'm not real pressured to buy until I find the right deal. Once I sell the KJ, i'll get a little more serious.
  4. TheBlueKJ
    TheBlueKJ Full Access Member
    1,613
    Oct 29, 2012
    South Jersey
    So if you have an old tired engine, NEVER EVER EVER NEVER put synthetic or synthetic blend in it. IT WILL burn and leak oil faster than you can put it in. That is all
  5. Atrus
    Atrus Full Access Member
    4,398
    May 15, 2007
    Metro Detroit, MI
    I'd like to throw a set of them on my WK as well, but sounds like I need to run spacers with them, which I am not comfortable doing.
    My plan is to lift and then run 255/75-17's. Would like to go to a 265, but I think I'll have issues with the upper ball joint stud/nut.
  6. sota
    sota Full Access Member
    1,506
    128
    you removed all the sludge blocking up the seals.
  7. TheBlueKJ
    1,613
    Oct 29, 2012
    South Jersey
    Thats exactly what happened
  8. Marlon_JB2
    Marlon_JB2 Kombat Edition Jeep
    15,012
    41
    Nov 20, 2004
    Clinton Township, MI
    These people are doing entirely too much just to disable the ESS. I've been used to it literally since Day 1.
  9. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,556
    117
    At some point in most peoples lives they will realize that their children and parents age much too quickly...
  10. Akley88
    Akley88 Full Access Member
    89
    Aug 28, 2017
    PA
    im pretty sure the jeep purposefully starts a new leak after i fix one i.e. fixed trans cooler now its leaking coolant at the thermostat housing.
  11. HoosierJeeper
    20,708
    81
    I just turn mine off whenever I get in it. It's second nature now.
    Ain't that the truth.
  12. Kal-El
    Kal-El Full Access Member
    541
    Dec 19, 2015
    Glendale, Arizona
    OK...before I google it...what's ESS?
  13. HoosierJeeper
    20,708
    81
    Engine stop/start. Shuts down when you stop at a stoplight and then restarts when you lift your foot off the brake.
  14. turblediesel
    turblediesel memberable
    2,296
    125
    May 31, 2015
    Alaska
    That would annoy me as much as my old boss's Nissan sports car telling me "the door is a jar".
  15. Jo6pak
    2,916
    76
    Nov 10, 2010
    Left coast of WI
    I've driven a few vehicles with ESS. I think I would get used to it. But my bigger concern is the wear/tear on the starter is a lot of city driving is regularly encountered. Perhaps there is some new tech to mitigate that?
  16. Kal-El
    541
    Dec 19, 2015
    Glendale, Arizona
    That idea is ridiculous for so many reasons... :Insane:
  17. HoosierJeeper
    20,708
    81
    Apparently it has an extra beefy starter and battery. But I imagine they'll still be less strained if I disable it. If I wanted something that felt like it'd stall at every stop light I'll drive the LR3:happy175:
    I'm not a fan at all.
  18. sota
    1,506
    128
    most of the ESS systems i've seen use much bigger starters than the norm. They also in some cases double as generators/alternators. Pretty sure BMW was doing it that way. Fewer revolutions to kick over the motor. I drove a stick shift Mini a couple years ago with ESS, and the system was fast enough that I couldn't pop the clutch before the engine was running. To do that takes some serious torque.
  19. TheBlueKJ
    1,613
    Oct 29, 2012
    South Jersey
    Swapped to rotella 15w-40 and all is well now no more leaks
  20. Leeann
    Leeann Full Access Member
    2,332
    99
    Mar 9, 2013
    Maryland
    Supposedly, the starter can handle the million stop/starts in a day.
    I've been next to vehicles that started when the light turned green and I've driven one that had ESS and I absolutely, positively hate it.
    My boss' daughter had the Mercedes salesman disable it on her car, she hated it so much.
