So it has been frustrating filling up my liberty only at a certain gas station that has super slow flow setting. Anything faster that the lowest setting will shut the pump off.
I think the problem is the flow management valve because when I changed the pump, one of the nipples on it broke off and I used the adapter to try and fixing it but it broke off again second time i dropped the tank. I couldn't get it out so I just jammed it in there and put in another adapter. Doing that I think I clogged it up and now it doesn't let the air go out as I fill the tank up.
I cannot find a part number for that assembly.
Picture is below and you can see the air vent nipple that broke off and I am pretty sure I clogged it.
Is it a removable part? Can I try taking it off and try and take the stuck adapter out of it or just replace it? Dropping a gas tank is a pain in the butt so I don't want to do too much. It's either a new tank or new flow management valve if I can find the part #.
Unless there is something else that can cause gas tank to shut off pump and splash gas this often?
