PSA- Re-Tourque your wheels.
Overlander BC
Yesterday I lost a wheel. Happened in a matter of seconds from feeling a vibration to the rear wheel stuffing into the wheel well and snapping a wheel stud off.
Aluminum wheels.
Yes I torqued them. And re-torqued them. And then drove it for half of August, September and this much of October thinking they're fine.
Please go tighten your lugnuts today. I talked to my folks (they own a Liberty as well) and said the same happened to them, although they caught it in time to not lose a wheel.
I'm a bit embarrassed that I didn't catch this. But let my embarrassment be your gain. It costs you nothing to grab a torque wrench and go make sure your wheels are good to go.
burntkat
They shouldn't need to be retorqued as you are saying. Are you using antiseize or grease on the threads? Hope not.
What are you toqueing them to?
Overlander BC
Every wheel needs to be re-tourqued after about 100km. Every single one. Steel or aluminium.
I use the proper specs. 85ft/lbs
No I don't use anti sieze.
I'm a retired mechanic. That's why I'm embarrassed this even happened. I forgot that people in tire shops all use air tools and don't give a crap.
It's the aluminum wheels. And 17 year old tire shop guys.
That's the problem.
I think what happens is that over the years, people don't use a torque wrench and crush the aluminum a bit by cranking the lug nuts on with air tools. And then this happens when you treat the wheels properly.
The solution is to RE-TORQUE the wheels, more often. It's the only way to correctly identify if they're at spec.
Or- throw the aluminum wheels in the scrap bin and use steel wheels like a normal person.
So guys, just re torque your wheels. None of this shouldn't have to stuff. Just do it.
burntkat
While I agree about the points you made, especially WRT unskilled labor and grease monkeys, I have always torqued the wheels when I install them, and pretty much left them alone til I remove them. 40 years of driving and never a problem.
Now watch, I'll have an issue next week since I have said this....
Overlander BC
I know right? I haven't had this issue either since about 1994 when I lost a wheel off a 77 Trans Am. Same thing, same drivers side rear wheel too. Only difference was the aluminum wheels were aftermarket instead of the original snowflakes. So it's been 30+ years.
Thinking back a few weeks, I took this thing offroad for about a 2 hour drive along a powerline road and it was really rough. I'm sure that's what started the loosening.
This is the first time I've even used aluminum wheels since another Firebird I drove maybe 5 times a year when I owned it.
My last Jeep was a YJ and when I built it, I used a paint pen to mark a line across all the hardware and onto the surrounding metal so I could visually inspect everything if it decided to loosen. And when I drove long haul we had plastic arrows that fit on the lugnuts so we could visually see if the nuts were turning.
Lesson learned yesterday. For what it's worth to check, I wouldn't be replacing a broken wheel stud and new lugnuts.
Oh and get this- I went to Napa for lugnuts and a wheel stud. The stud was like 5 bucks and change. But they wanted 9 dollars per lugnut for Dorman lugnuts. I was like you have to be joking. They said dont blame us, blame Dorman. So I ordered 20 on Amazon for 26 dollars, directly from a Dorman supplier. They blame Dorman, but they're the ones marking em up. That's around 1000% markup.
