Protek's trail rig
protek yer neck
Northern Ontario
paid a cool 2g's and took the new jeep for some pozer shots this weekend, just across from work so if I broke anything I could go get it with the forklift. think I need to soften the leafs for more flex.
protek yer neck
Northern Ontario
the guy I bought the truck read the post and sent me a pic in my email explaning why the leaf stack is so thick
protek yer neck
Northern Ontario
I don't want a street legal rig, time to build a trail rig, first the bumper has to be stronger for "phase 2" so I'll call the bumper "phase 1" stock bumper removal was easy, I only had to cut every bolt.
cardboard temp 1:10 scale lol
now in metal (8" channel)
the notch is for the tow hooks to clear also we did'nt have any 2" strap to cap the bumper so we made some
and that about enuf for tonight, should have it mounted tomorow I'll leave you with a pic of my brothers mint bucket and a sneek peek of "PHASE 2"
protek yer neck
Northern Ontario
I did'nt get alot done today but theres always tomorow.
custom 1/4" 3x4's bolted to the end of the frame rails, I was going to weld'em cause if I have to remove the bumper I'll have to cut the exo anyways but this should work.
protek yer neck
Northern Ontario
I always wanted to exo a truck and theres not enuf exo build theads, trust me I've been looking.Mounted the bumper today, a little higher than the mock up for a undisclosed reason
I dont know how this will be looked upon, but is my truck. I like the
brush gaurd that was on it. I know brush gaurds are weak but welded
straight to a 8" channel bumper it should stand up, plus I drew up a ton of
front pipe work but could'nt come up with any thing I liked so I cut the
stock bumper mounts, into 8" channel mounts. Also the original idea for
fog lights mounted in the bumper might not happen we'll see.
I bent a stinger, did'nt bend the greatest. My pipe bender does'nt bend
over 100* very good, might have to have it done for me. fun to screw
around though. I dont know how long the final stinger will be this one is
3' long and it is a trail rig so huge isnt an issue for me I sorta like big.
I will start exo this weekend for sure.
protek yer neck
Northern Ontario
We welded up the bumper friday night, super thick triple welds.
I let my brother try the sandblaster, he's in love
Primed ready to exo
protek yer neck
Northern Ontario
Now Saturday Exo time. We only had a few hours but there was some progress. I didn't take alot of photo's, it was going good and I didn't want to mess up the flow we had going. tomorrow the front should be completely done.
protek yer neck
Northern Ontario
Sunday... dam, one piece shy of my goal, looking like a exo'd truck though
I don't know if anyone hase used a pipe bender befor but bending a pipe in
8 diffrent spots and keeping it straight is hard as hell. The pipe that runs
accross the windshield took me most of the morning.
We tied in most of the cage except for the one from the rear of the front
wheel well to the windshield, I have time set aside tuesday for that piece.
Figure if it'll be parked outside for a few days I'd better prime it, with the
rain we've been having I dont need the jeep turning orange, its going to
be hard enuf to paint as it is.
protek yer neck
Northern Ontario
CRAP! the shop was busy tonight so I got no exo done, on the lighter side I went for a ride (haven't gone in a while).
I think the hundred and some pounds the exo and bumper added help keep the wheels on the ground.
Washouts or crevices are my favorite its impossible not to get flex'y
maybe not...
I started taking the doors off but cant get the pins free anyone have any incite? I'd like to be able to put the doors back on I just cant handle the small xj windows. the wiring you ask i got multi plug's
protek yer neck
Northern Ontario
I couldn't get my hinge pins out in a civilized manner, so I cut the pins in half with a cut off saw, then stuck a screwdriver in between the two halfes and pried them appart. One half came out and I could punch the other through. I just replaced them with some clevis pins.
I went crevice hunting after working on my stuck e-brake, WARNING IF BODY DAMAGE MAKES YOU SQUEAMISH LOOK AWAY, no seriously the only photos I got tonight are the ones from the iphone Ill post more pics of the dents and scrapes later
Ya!
Body damage!
broken mirror!
rippled fenders!
and the true carnage! the front 4 link under the passenger side axle snapped off got new ones in the works right now be fixed tomorrow
also not pictured is a drag link bent so bad the tires sit like this /----\
protek yer neck
Northern Ontario
More carnage as promised.
The fluid on the ground behind the jeep is not serious unless it happened on the trail, it was the ice water out of the cooler :party52:
protek yer neck
Northern Ontario
Heres the new 4 Link bracket added on Saturday nothing fancy, it wont be around long
protek yer neck
Northern Ontario
protek yer neck
Northern Ontario
I'll be going out Saturday, same area I have lots more exploring to do, make a run out of it? some of the pics are from Garson pit area and others are from the "Happy Vally Wastelands" (named it myself)
Exploring Garson Lake
protek yer neck
Northern Ontario
New meats! :gr_grin:
other stuff in the works are reworked 4 linked front end, drive line brakes, front axle truss, completed exo, rollcage, hydro assist steering, 5 point harness, major transfer case reworking
sadly the rear will have to stay leaf because of a lack of money... for now but, I will do some work with an anti wrap bar
I do plan a rear four link with 2.0 airshocks but a tube buggy might happen before that, we'll see
protek yer neck
Northern Ontario
Axle truss started :smoke2:
alot of cardboard died tonight
I got some diamond plate,
protek yer neck
Northern Ontario
I found a 4" slug at work, just so happens it fits snugly into my spring.... also drilled and taped it for a coil retainer, and made some large tabs for the rodends I'm waiting for
while decommissioning a ten ton at work I grabbed this
so its done. complete install of air horn, its loud . here it is, in the sneaky location
protek yer neck
Northern Ontario
the XJ now has Dana 60's, the front axle was moved ahead 7" from stock and the rear was moved back 5". stupid me forgot my camera, so crappy cell phone pics it is... till tomorrow
the front axle was moved 2" or 3" forward by previous owner, I did the rest because the four link calculator told me to, allows for more flex and better approach angles
protek yer neck
Northern Ontario
old parts /new shackles, plus I moved the rear shackle mount forward to help with the ride hight, not permanent, just till I 4 or 3 link the rear
all links are dom/sleeved
I call this a shock fin (like shark fin) had to ad'em for more droop... I need new shocks
