problem after lift
Cidghoul
Philly Burbs
Just got done lifting-ome hd, bilstein, al's uca, al's top plate, 3ring clevis, extra rear iso, and went to test drive it and it felt very unsafe. During turns it feels like its wobbly and loose then as speed was gained maybe 25mph hi pitched squeel from drivers side front that was related to speed as it slowed down and stopped as the vehicle did. Any help would be much appreciated. Oh and it's not alligned yet could that be the problem?
1BADKJ
Barnegat NJ
Your alignment is so far off right now. Just got done lifting arrtic libbys jeep. Was +2.34degrees off.
Porkchop
Troy Mi
It will its like night and day difference and if there is any problems thay should let you know. Let us know how it comes out seems like not all shops know how to do a lifted liberty. You might want to look up post on it before you go so you know before you go.
NJallDAY
New Jersey
How are the lower ball joints? Mine were toast after i lifted it, i didnt notice it until it was on the alignment rack and then i had to replace them before the alignment.
Cidghoul
Philly Burbs
Well this may be a problem. Just measured and the front is sitting 24" center hub to fender.
Cidghoul
Philly Burbs
Now im really confused backed it up a few feet to jack it up n make triple sure everything is tight and it dropped to 21.5". Pulled forward again and 24". So when i drive forward it raises and reverse it lowers. I think im losing it.
Cidghoul
Philly Burbs
Wow it was the alignment! :worthy:
fixed everything sitting 22.5" all around
Crazy stuff.
