ShafferNY
I'm thinking about replacing both rear calipers on my Liberty, but retailers sell two different types; phenolic or metal piston calipers.
From the short amout of research I've done, the phenolic is supposed to transfer less heat to the brake fluid and caliper/axle, but also has the tendancy to stick in the bore. (OEM calipers are phenolic)
Metal piston calipers have much less tendancy to stick, but tranfer heat more as it is a better conducter.
Any opinions?
My first thoughts are, if they used metal for years without issue, whey go to a plastic composite?
Any opinions?
