Chillbilly
I have a left parking light which doesn't work. The turn signal works fine. I've tracked the problem down to the socket which the unit plugs into, part of the wiring harness. This is not the bulb socket, but the socket which the entire unit plugs into. Apparently this socket has a problem. There is voltage in the wire coming to the socket, but no voltage at the contact. I need to replace this socket. Has anyone any experience with this. I could really use some advice/directions to replace this socket. I can be reached at [email protected]
