Surprisepoptart
- Joined
- Nov 29, 2022
- Messages
- 11
- Reaction score
- 3
So, I'm closer than I care to admit, to throwing in the towel on this one...
I'm dealing with a rough idle and check engine light. The codes says cylinder no. 4, and that's been verified by unplugging the coil pack.
Give it some revs, and it smooths out around 1000-1200rpm.
Give it any load, (like trying to accelerate) it also smooths out even sooner.
Swapped plugs, swapped coil packs, swapped injectors. Even replaced the ecm.
It's getting spark, I can hear it arcing to the plug if I lift the coil out while it's running.
Passed a compression test, and the valves look intact based on what I could see with a little flexy inspection camera.
I want to do a leak down test next, just haven't gotten to it yet.
Only other "symptom" would be a very slight, somewhat intermittent rattling noise from the front of the engine. I'm guessing one of the plastic timing chains guides retired.
What else am I missing? Could a loose timing chain be causing a misfire only on a single cylinder?
Maybe a wacky crank position sensor? I'm at a loss for what to try next
