overheat
Jack2282
anyone test for failed head gasket and actually find one? if so what symptoms started the testing, and what tests did you run and what did they show-this is very important for us all dealing with over heating
When my hg failed in my 02 kj I had a milkshake in the crankcase. I have used a pressure tester to apply pressure to the cooling system and found an "external" hg leak on a Subaru. If you're leaking alot from combustion chamber into coolant you'll know by the boiling coolant. If you're getting exhaust in the coolant from a smaller leak, there are kits to test for exhaust gases in a coolant sample.
