adamkrz
Any tricks getting the top to fit in - seems about 1/4 inch to wide and I don't want to bend the mount any more. Should I grind the metal bushing inside the rubber grommet? Thanks..
Most likely the upper mounts got crushed in from the old shocks being over-torqued(OE shocks or Durango rear shocks?).
Take a threaded rod, or full length threaded bolt. Slip that through the mount holes with a nut on both ends inside the upper mount. Then crank the nut(s) out to spread the bracket back apart.
