OME 2790 questions
raf3
So I am planing on lifting my 06 KJ and want to eventually add a winch and bumper. Should I be using the OME 790 because of additional weight or will the 927 be fine? Will the 790 spring raise the front more than the 927 until the bumper and winch are installed? Thoughts - thanks.
WHEN,.........you have an ARB and winch then you can run the 790s, running them with no extra weight up front is going to be a very rough ride
927s will work for a while with just the ARB, but not winch and ARB
raf3
Thanks for the quick response. How about the height difference without the extra weight? So if winch is coming I guess we have a rough ride for a while? No problem with fit of the 790s?
raf3
I am ordering OME 1.5 lift kit for KJ (790 & 948), rear bump stop 4", and tera flex bump stops. Anything I am missing?
