Old skyjacker lift fix?
rustydread777
Active Member
So i have a 2002 jeep liberty limited with the.3.7 and 45rfe. It had a skyjacker lift that was installed before my time. My dad owned the jeep before me and someone else 5 years before him. It has a skyjacker lift and sits as follows;
front right 21"
Front left 20.5"
Rear right 21"
Rear left 20.5
So i understand that this 1.5 to 2 inches taller than the stated 2002 factory 19 inches.
The rear shocks are the old rancho socks that are no longer in production but still dampen.
When going over speed pumps or hitting the brakes hard she is taking a nose dive and I can visually see the front left shock is leaking, the front left is done for sure and I'm sure the front right is too follow.
From what I've read is that the skyjacker is initially had good spring rates and held the jeep up well before they changed it, these might be them given the height i listed.
I'm planning on transfer case skid arb front bumper with winch, transmission skid, and i have kk clevis forks to add a tad more lift. I have all those parts in my garage.
Would the struts be worth it to rebuild for $300 for the new socks and some elbow grease.
Or go with DIESAL quick struts clevis forks and a spacer.
Currently sitting on 225 45 16 and will go with 245 75 16 with moabs when I drop in the 4.10 front and rear sitting in my backyard.
To clear up the options: On the Liberty you don't "rebuild" a shock—you just take the assembly out, compress the coils, toss the leaking shocks, and replace them.
If you go with "diesel quick struts" and stack spacers, that heavy ARB bumper and winch will crush those stock-style springs in no time. You'll get massive sag right away.
If you're on a budget, your best cheap option right now is to keep those Skyjacker coils. They are naturally stiff, which actually works in your favor for holding up that front-end weight. Just swap in new shocks (like Bilstein 5100s) inside your current coils. If you need a little extra height after that, you can use those KK clevis forks or add clevis rings to fine-tune it.
Also, don't worry too much about that 1/2" lean right now—that could easily just be an uneven driveway or settled isolators.
If you ever want to do a full upgrade down the road, heavy-duty linear springs designed for bumper weight (like OME 790s) are the ideal fix. But for now, fresh shocks in your current Skyjacker springs will get you rolling safely without wasting money on quick struts.
rustydread777
Active Member
Thanks for the input. So this happened the other day. Took off a wheel to look at the shock and decided to change the ball joints impulsively. Realized that the clevis fork was all the way up on the driver side and the passenger side was slightly dropped away from shock and causing more lift on the right. Made them even and yielding 21.5 on the front now on both sides.
I found a super lifted liberty at a yard and going to check that out this weekend to see whats under the frame suspension wise.
Shankster
Durango, Colorado
I second the Bilstein idea (24-139168 front, 24-185240 rear - those are 4600 series though). Would be a bit more than the $300 shock/stut rebuild but well worth it IMHO.
rustydread777
Active Member
Is there anyone who sells the ome front coilovers assembled? Don't feel like buying a spring compressor
2TALL1
Eastern Oregon
So there is a couple places where you can buy fully assembled OME spring assemblies.
And there might be other sites.
But really you will need a front end alignment after you install a lift.
Most places that do alignment’s also have the ability to compress your springs for you. And will usually do it for free or a discount if you use them for the alignment.
With that being said it’s cheaper to build your own!!!!
Buy the springs you want (I always suggest buying straight from ARB/OME. When you buy from anywhere else they just drop ship them from ARB/OME anyways. Skip the bull ***** and buy from the factory!!!)
Or whatever spring you decide to use…
OLD MAN EMU… OME
BDS
IRON MAN
H&R
Either use your existing top plate or purchase a new one. They are fairly cheap.
If you use your existing plate they will have to disassemble your current assembly for the top plate.
I think the factory top plates are superior to the aftermarket ones but most have been swapped out already for cheap assemblies over the years on most jeeps.
You should always put new spring idolaters in with springs. They are cheap and go with factory OEM ones.
SHOCKS:
This is always a hot topic.
Buy good ones!!! At this point they will probably outlive your Jeep.
In the U.S. I would suggest Bilstien or OME with OME springs.
Just from my research KYB’s seem to work well with H&R springs for people abroad.
There are a ton of different variations that have been used. (Seriously read the LIFT KIT section!!! Start at the beginning and see how everyone used to do it and how things have changed over time. Take notes and come up with your own plan!!!)
Take it all to your local suspension/alignment shop and have them assembled and BAM!! You have shock assemblies built how you want.
rustydread777
Active Member
So I've been looking around and I've learned that the ome 1.5-1.75 lift stated in the advertising is apparently actually true now and will not yield the 2.5 inches they used to say in forums that one will actually get. So I would need to install my clevis forks (1 inch extra lift) and a 1/4 top spacer (.5 inch extra loft) to achieve the 2.5 or so inches. I reached out to rro and they quoted me the assemble struts for 850 with 2790 and emu. Sounds about right. I checked my skyjacker springs Dimensions with a caliber and apparently they are the softer soft ride and not the original stiff springs so im feeling now too just replace the leaking strut for $150 and call it a day and stop on all mods and save like $1500, or go all in.
Thanks for all the input.
2TALL1
Eastern Oregon
Not sure where you are getting your information on OME springs only giving 1 1/2” of lift at. But whoever or wherever you got this information is wrong!!
OME has ALWAYS only stated 1 1/2” lift. But everyone knows it yields 2 1/2”
$850 seems spendy not sure what they actually quoted you but it’s around $650 from the company that actually makes them.
I truly believe you should just take it to a shop and have new cheap whatever shocks installed and call it a day…
rustydread777
Active Member
that was quoted by RRO for assembling the front struts. looks like $200 is the going price to assemble them. Thanks for that direct response 2tall1. I've always been a maximalist, and I don't plan to stop now. I saw your build and I'm all in.
