OLD MAN 2882 spring
t-tomer
isr
hello everyone!!
i have some idea to put OME 2882 in the front of my kj
it has same rate as the familiar 2790 but with a free length of 395 mm (about 17mm more than the 790's)
this will allow me to alight the vehicle as i need (i have winch, bumper and 3 rear moog spring seat rubbers)
what do you think?
i just missing the inner\outer diameter of the spring, can't find that information.
dude1116
Pompton Plains, NJ
hello everyone!!
what do you think?
It needs to work with the front insulators and mount. I doubt it will be plug and play. And at that rate, you're still limited in height to the length of the shock...not the length of the spring. The spring needs to compress more to match the length of the shock, which will actually change the spring rate.
Have you already added top plates and clevis space??
t-tomer
isr
I forgot to mention, my set up currently is IronMan shocks and springs and jba UCA 4.5 and 3/8 clevis
the height different between the front and the rear now is 65mm
as i lift my vehicle with a lifting machine, i can see i have enough suspension travel to alight the front (compared to the rear of course) so the shock are fine.
my second option is to get the OME2970 with 2 JBA Strut Spring Ring on each side but i'm curious about the OME2882
dude1116
Pompton Plains, NJ
I would suggest getting the normal OME spring. They tend to not sag as much as the iron Man springs.
No bad idea , strut sprung rings will make the 790 carry more pounds yes, but will make them very rough riding, bad idea all around
As far as the OME springs, no your thought process is sort of going the wrong way and if using them ( the 882 ) front will not function as it should
Use regular 927s if no bumper / winch, with an aftermarket bumper and winch then 790s
