Oil leak front axle
Dane
I’ve noticed an oil leak from the front drive shaft where it connects to the front differential. From my searches I’m guess it’s the outer Oil Pinion Seal? Does that sound correct and how hard if a job is it?
it looks like it would just be dropping the drive shaft popping out/in seals and replacing the driveshaft.
Almost that simple. Gotta take the pinion nut and the driveshaft ****** off. Getting the pinion torqued properly is the only hard part.
