ALLENGUA
Well i went to change my oil this weekend and come to find out my oil drain plug just spins around and dose not come unscrewed is the cast oil pan threaded or is the a nut on the inside of the pan??? NNED HELP !!
power train will not cover the oil plug called 3 dealers .... oh well
Have you been doing the oil changes yourself, or taking it somewhere? If you took it somewhere, bring it back to them and make them replace it. If you have a receipt from the last oil change they cannot deny they did the work, however if you don't, you would probably be in their computer system, and they should be able to look it up.....if they're even the least bit decent of a shop.
I ended up buying a new oil pan ($800) and installing a fumoto oil drain.
