NP 231 Transfer Cable Problem
Liberty Renegade
Buffalo, NY
Hello Everyone,
I have a 2003 Jeep Liberty Renegade, 3.7L Engine with the NP 231 Command Trak transfer case (Part time 4 WD). I had issues with the transfer case not shifting and the case popped out like 2 times when i tried shifting. Never bothered about it later and since i never needed the 4 WD in summer.
Took a look underneath and the Grommet / Bushing holding the cable eye to the transfer case selector plate pin is shredded. I am having a hard time finding the replacement part or the cable assembly.
Any ideas, suggestions or part reference is greatly appreciated.
Thanks,
Anoop
Liberty Renegade
Buffalo, NY
Solved
Thanks for the reply, That part, thought shown for the NP231 case, does not fit. Its meant only for the wranglers.
Finally found the exact match. Other Chrysler, Jeep and Dodge owners will find it useful too, since all these brands make you change the entire cable instead of the bushing alone.
Doorman part 14044 - Shift cable bushing
http://www.dormanproducts.com/p-23718-14044.aspx
$9 part as opposed to $270 cable.
Pass on the word, for not much people know about this.
hodgesjl
Virginia
When I check fit for this part, it only let's me select for manual transmission and mine is automatic. Is there o e for AT?
sevenhelmet
Ridgecrest, CA
I just got back from a wheeling trip where I couldn't shift out of 4LO, and my bushing was just GONE. The cable and control arm on the case are just fine though. Weird. Wonder if it came off in the underbrush, or if it's been missing for a while.
Thanks for the part #, I'm going to pick mine up later this afternoon.
