I have a 2005 Jeep Liberty KJ 2.8 CRD that originally ran properly but now has almost no power under load. It starts, idles, and revs normally in Park/Neutral, but when shifted into Drive or Reverse, the RPM drops and the engine will not produce enough torque to accelerate. Heavy black smoke is produced when throttle is applied under load.
Fuel rail pressure follows commanded pressure, accelerator pedal signals appear normal, and I have verified the fuel supply side with an external diesel source.
I’m currently focusing on the EGR/air-management system. The FCV (EGR throttle/air-flow control valve) does not appear to be functioning correctly in normal operation, although the active test can move it, and closing it causes the engine to die as expected. The EGR actuator test also affects engine operation same as the FCV. I also have a P0403 EGR solenoid circuit fault, and circuit testing has found an intermittent/high-resistance condition in the EGR solenoid wiring.
The vehicle has had recent head/timing work, and I’m trying to determine whether the FCV/EGR system or its control circuit could be contributing to the severe loss of power and black smoke under load.
I'd really appreciate some constructive ideas. I've been working on this for way too long and really want to get it running again!
